  #614 (permalink)
Old 02-14-2011, 06:30 PM
DMXF DMXF is offline
Original Shelby Owner
Cobra Make, Engine: 31XX Car
Default Torque vs HP
Originally Posted by Mdman352 View Post
What gets you to the finish line first??? Torque or horsepower???
Does it matter if a motor makes 600 horsepower at 5800 rpm or 7200 rpm???
Alot of the myths are debunked here: http://www.lainefamily.com/hp.htm
The big problem with making alot of torque at a lower rpm is greater difficulty in getting the tires to hook up, then the power drops off after you're going down the track when you need it most. A number of the highly turbocharged tuner cars limit the boost in the lower gears so you can get off the line better and then they let it come in after torque multiplication is lower in the higher gears.
