Old 02-15-2011, 03:20 AM
OZVENOM's Avatar
OZVENOM OZVENOM is offline
Cobra Make, Engine: Now built a race cobra.
Default getting it right.
Hi if you want to get it right it has to be all mounted in chassis . when on the ground at ride height you need 1- 1.5 mm of toe across the rim. Each side it will make the cobra drive stable in corners and on roundabouts. its is a lot of work to pull the arms in and out so put say .010" of shim under the rear bolt of the pivot block when you assemble it a good place to start.
Thanks for the mention Rebel.
I dont like to pedal my wares on here. as i am not an advertiser on cc.
Regards oz.
Left Foot Up Right Foot Down.
http://www.venomcobras.com
