Old 02-16-2011, 10:41 AM
Stephan427SC Stephan427SC is offline
Unhappy FAST Dual Sync Distributor - need help !
Hi guys,
does anyone of you know, how to install and phase the FAST dual sync distributor ?
I use it with the XFi ECU and a 8stack-system from inglese for a ROUSH427R.
What I did up to now :
I turned the engine to 50°BTC and installed the distributor facing to #1cylinder. Then I turned the distributor (with power on) clockwise until the first red LED (cam signal) gets on. Then I turn clockwise until this light gets off. After about a distance of 5mm the next red LED gets on (crank signal). From here I turn back anticlockwise until the red LED of the crank signal gets off and fix the distributor. Is that right what I did up to here..?
In the manual is told "find the leading edge" of that signal....what does that mean exactly ?
Thanks, Stephan
