Old 02-17-2011, 03:44 AM
Zedn's Avatar
Zedn Zedn is offline
I can tell you that it has Jag front and rear. With the front end using a shortened jag cross member. I thought that RCM was the only one that used the jag cross member. That makes me wonder if it is an RC Sports Cars kit.
Anyone seen the old RC chassis?
As for testing documentation. In NSW this is an issue as the RTA are starting to ask for seat and seat belt anchor testing. But as far as i know the only test you would need in Vic would be torsion and beaming. Factor in about $1500 for this test. All other tests such as braking, lane change etc would probably have to be done with any kit unless identical to one thats already been tested.
If its cheap enough and the welding is of good quality its worth considering.
