Old 02-17-2011, 03:55 AM
blykins blykins is offline
Originally Posted by YerDugliness View Post
I've often wondered, Bob....my hope was to avoid excess "wear and tear" on the rod bearings by not starting the engine without lube on them after having set up for a while. I believed that disconnecting the coil wire would eliminate the "pressure" of the combustion event, hoping that the bearings would be spared the pounding from the exploding air/fuel mixture until there was lubrication from the dry-spin by the starter.
Best way to do that would be to just remove all spark plugs. This way the engine will almost free-wheel with the starter. Just pulling the coil wire by itself will still allow compression to build in the cylinders.
Without a doubt, the Accusump is the best way of handling a dry start. However, if one is not available and it's been a couple of weeks since the engine has been started, then I would use the method above. Keep in mind that a bearing will probably never be absolutely dry with oil. I've torn down engines that have been sitting for years and the crank journals/bearings still have oil on them.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
