Old 02-18-2011, 02:57 PM
sam-tip sam-tip is offline
Default adding ammeter to CRI
Wanting to add a VDO series 1 ammeter to my cr.
Does this make any sense? Wire diagram link is below
This would be easy on new system. But this is a 17 year after thought. From the VDO wiring diagram I would cut the battery wire (always +12 volt) going to the ignition switch and reconnect it to the +B terminal of the ammeter. Then connect red wire from the alternator and the other end of the cut ignition switch wire to the +L terminal.
http://www.egauges.com/pdf/vdo/0-515-012-154.pdf
Thanks
Doug
File Type: pdf Samsung SCX-6x55 Series_20110218165113.pdf (23.0 KB, 208 views)
