Old 02-22-2011, 06:00 AM
Mark IV Mark IV is offline
Senile Club Cobra Member
Best guess is that the street engines came "dressed" from Ford and therefor would have "AUTOLITE" marked belts as were used for regular production. However the engine assembly manuals I have indicate that much of the engine dress was done at the assembly plant, i.e. power steering pump and bracket added, A/C comprsessor if so optioned. As the Cobra only had the water pump and alternator driven, it could be assumed that that was dressed at the engine plant. I can look up the FoMoCo part number and engineering number for a 427 with no acessories.
Marti Autoworks has reproduction Autolite belts but they are current style with original type markings.
I would assume that Shelby used a local source for the radiator hoses and they may be Ford or not. The "Atlas" belt you have is a 1960s aftermarket line that was commonly distributed in service stations (remember those?) and would not be OE.
from stories that are told about "production" as SA i would guess that many small items were locally sourced and not from the FoMoCo parts bins as one might assume.
rick@autoventureusa.net
