Old 01-24-2002, 07:31 AM
Okiesnake's Avatar
Okiesnake Okiesnake is offline
Cobra Make, Engine: Unique 427SC, 351W
If you want, you can push the floating base in and then rotate the base 180 degrees. Be careful not the break the off the ears of the contact base. It would probably be safer to simply switch the leads into your wiring harness.
