Old 02-22-2011, 05:49 PM
wetdog wetdog is offline
Cobra Make, Engine: classic roadster,408cu
Default proper procedure ?
When installing the intake manifold on a 351 is it necessary to coat the intake gasket , or put silicone around the water ports ? some say coat the gasket and glue it to the block , and some say just put it on no sealer required and seal the corners with silicone .
Wont the head to intake seal without sealant? except at the corners...WD
