Old 02-24-2011, 07:55 AM
patrickt patrickt is offline
Originally Posted by DonC View Post
Patrick:
Thanks for the information and references. Hope it will be straight forward from here.
RE: Ground. Triple checked the wiring ground and used a frame pick off as an alternate so I was absolutely sure the ground was good.
DonC
Don, what I would do is pull the two fast blow fuses out of the fuse fixture and put them over on the workbench. Then I would jumper across the fixture as I have marked below with two pieces of wire with alligator clips on the ends. Then test out your lights on both sides of the car and tell us what you see.
