Old 01-24-2002, 12:18 PM
bad_sss bad_sss is offline
I'm using Wilwoods on front and rear. I have Tilton pedals with a balance bar, and am using 2 psi in line valves. I would definatly use a proporting valve if you do not have a balance bar; you can't expect the brakes to 'fire' perfectly; you will have to adjust them.
Also, don't forget to fit an in-line pressure brake switch, unless you have another way to signal the brake lights.
Good luck...
Dan Hillman
Austin, TX
