Old 02-26-2011, 08:49 AM
Caprimaniac's Avatar
Caprimaniac Caprimaniac is offline
Cobra Make, Engine: Unfortunataly ; none
Oh, you're all awake at this time... I've having a bad morning with a hangover from yesterdays beer & that awful rom & coke.
Anyway, you all have good input, and I agree with you all -partly. Yes, it need to go with the shims. And yes, the roller will still hit the valve stem tip at the inner part (towards the shaft) of the diameter. This is desireable because the rate at start of valve opening will increase and a increase in valve giude wear can be accepted.
By using more/ other shims it might be able to get the geometry even better. But, after all I have read & understood, I cannot see there's much to gain.
Yes; I will check pattern on stem tip. After rolling over a cycle, it looked very promising, rolling to and fro the centre.
You are correct on the pushrod clearance, Blykins. Very tight, but OK with a 5/16" rod. (again by eye, will measure.) Although, I have been looking at going to 3/8" PR... What do you think?
A 5/16" cro-mo one piece 0.080 wall will hold up quite a bit?
And I'll need 0.05 shorter PR for the inlet than the exhaust as well.
What I thought of the Jesel parts? Looks quite sturdy. BUT. If I had the tools to fabricate, I might have done otherwise. Why not make the platform in aluminium instead of steel? The size makes it very heavy. And why not use a one- piece shaft? OK; much easier to change one unit with two shafts. And with a one piece shaft, it might be other issues regarding spacing the shafts.
But, I think the instructions that came with the parts are a bit too vague. I was also shure there were a PR lengthchecker in this kit, but there wasn't. (spent 30min making one up while I could have one for 11$).
Let's do some more work & this will be ready in a day or two.
