Old 02-26-2011, 06:41 PM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
If you try a cylinder leakage test without the piston at the tdc(not just on the way up) the air pressure will blow the piston down to the bottom and will cause any wrench /socket you have on the crank bolt to be turned violently at high speed. Not this can cause several things ----one of which is to cause the crank bolt to be loosened ---
