Old 03-01-2011, 08:57 AM
Z-linkCobra's Avatar
Z-linkCobra Z-linkCobra is offline
Cobra Make, Engine: Everett Morrison, All aluminum small block ford.
I tried for a whle to figure out way to get one in my EM. The 2 problems I ran into were:
1. You'll have to notch the gas tank to make it fit.
2. The pinion center is quite a bit lower on a quick change making pinoin angle a real nightmare. You'll have to raise the rearend in the chassis quite a bit to get your pinoin angle back where it needs to be. Then that car sits too low in the rear. You could drop your tranny tail down a little to try and fix it...but that creates more problems in the front.
I played with it for about a month before I gave up.
" If it wont break em loose in 3rd gear, it aint enough power "
