Old 03-01-2011, 05:46 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Default ZF Differential change & Others
When did the ZF differential become standard on the Superformance MKIII?
Perhaps you guys with newer chassis can chime in on this one with chassis numbers...
I also understand they are also using a Smiths fuel gauge now with a white plastic back housing, (looks like the AMP Meter) requiring an additional ground wire to the fuel gauge...I have this change on chassis #2907...if its on any earlier chassis is unknown? Once again you new owners can check this...
Also the new internal parking brake...anyone got the earliest chassis number on that modification?
Just updating my records....
Thanks all...
SPFWiringDiagrams@Comcast.net
