  #23 (permalink)
Old 03-02-2011, 03:24 PM
blykins blykins is offline
Originally Posted by 4pipes View Post
That guy driving Seca was only in two gears....3rd and 4th, so when you say he wasn't pulling, he could of used 2nd. The fact that he can do 1:45's at Seca with two gears is astonishing for a 3600 lb. car.
Most magazines peg 0-60 times around low 4's, so much for slow around town.
Good point about using 3rd and 4th gears.
On the 0-60 though, you don't take off like you were taking off from a stop sign. You take off with as much throttle as you can without breaking traction and then start slamming gears. Not quite the same....
You don't drive downtown in a parade doing drop clutch takeoffs and speed shifting.... (or at least most of us don't)
As I said earlier, that's a phenomenal amount of horsepower from 5 liters. However, the torque is very disappointing and I would imagine that the average horsepower is very low as well. Combining that with a heavy car and a semi-low rearend gear, I think there's a lot more to be desired. That's an engine that would constantly have to be kept at screaming rpms to be competitive.
As an engine builder, this is at the exact extreme of what I would build for a street engine. I tell my customers to try to make the most horsepower in the rpm range that you will be driving. Street cars don't spend any time at 7750 rpm.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
