Old 03-02-2011, 06:43 PM
dont's Avatar
dont dont is offline
Cobra Make, Engine: SPF #1235
Originally Posted by ramey View Post
mine was a 5/16 line with a volkswagen fuel filter... you have to pull all that garbage out and completely replumb the fuel system... the stock line is not even big enough for a return line.
if you go with the stock stuff, you are limited to about 350 rwhp, and if your motor wants more you'll burn pistons.
also, if you want to drive the car, the stock tank pickup will starve unless full in any corner... especially if you fuel inject the car.
you need to pull the tank and either put a cell in or cut it and put proper reservoirs in.
the car was just not designed to be raced. they are nice, but nice show cars.
I've got 440 RWHP with the stock lines, filter and mechanical pump. Have not had a problem on the road coarse or drag strip.
Superformance #1235
460/T5
