Old 03-03-2011, 11:27 AM
wideglidejoe wideglidejoe is offline
Cobra Make, Engine: FFR MK III,462 FE/TKO 600, IRS w/3.27
Dirty Dog,
I think you'll be pleased with the Precision Oil Pump parts. I've purchased their parts, they make good stuff!
After reading all of this, I'm just surprised (and lucky) I didn't have a major failure back in the '60's. I hotrodded several FE combinations; mostly stock except for cam swaps, headers and bigger carbs. All using stock Ford rocker arms, both adjustable and non-adj, and the only FE failure I had was a timing chain stretched and jumped a few teeth on a warmed over 390 after 100,000+ miles of hard driving. Luckily no bent valves, etc.
I'm amazed at all of the FE knowledge that everyone has posted here. I've incorporated that info on my current build; FE oil mods, roller rockers w/end stands and shaft spacers, timing advance (initial and total), etc. All of this stuff has changed for the better since the 60's! Today we are in better shape for FE stuff than ever before.
Wideglidejoe
FFR#6143 Mk III: FE 462" w/four 48 IDA Weber's w/TKO 600 .82, IRS w/3.27, 17" Team III's w/245/45's & 315/35's. Gas N's.
Picked it up end of Aug '08
First start May 12, '10
First go kart May 26, '10
Tag & title 5-26-11, driving in gel coat
Painted Nov 2015
'05 Harley Wide Glide (60 hp stock, now 107 hp & 107 ft/lbs at wheel. Mid 11's in the 1/4 mi.)
'55 Bel Air hot rod project (WIP)
