Think that's enough?...sunny, hot summer day, end of a spirited drive, car parked in sun, heat soak from engine & headers, no airflow...etc...
Perhaps a MSDS on the foam material you can purchase at JEGS for the same usage would give you a feel for the temperatures commonly found under the hood? Maybe knowing what temp vapor lock occures at will give an indication of the common under hood temperatures you can expect to see...Heck, your coolant is 195 degrees minimum...Just thinking out loud here...
SPFWiringDiagrams@Comcast.net
