Old 03-04-2011, 09:38 AM
patrickt patrickt is offline
Originally Posted by Jerry Clayton View Post
c3az-6250-d
Not that fat, Brent knows I have the old c3az-k grind that came with the 8v 427 cars. They've come a long way in 45 years, so I would understand if he didn't want to take a "step back in time." Here's the specs of the K cam off of a Cam Doctor machine (not my machine). Basically it's 245/.525 at .050 -- 324 seat to seat. I have it installed 5 degrees advanced for an ICL of 109. It has a nice following over on the FE forum, but it's admittedly old technology.
Lobes I5, E5
Lobe Seperation 114 cam deg.
Checking Height 0.009
Valve Overlap 95.4 Crank Deg.
...............Intake.............Exhaust
Center line ...111.00ATDC.........117.00BTDC
Open...........44.48.BTDC.........92.29.BBDC
Closed.........87.88.ABCD.........51.04.ATDC
Duration.......312.3 Crank Deg....323.3.Crank Deg.
Area...........26.32 Inch Deg.....26.44..Inch Deg.
Lash...........0.0160..............Same....
Rocker Ratio...1.73................Same
Peak Cam Lift...30308.Inch.........30357.Inch
Peak Valve Lift..0.50832.Inch......0.50918.Inch
Spec.........Value................................ .........
Checking Height...0.050..Inch
Valve Overlap.....16.9...Crank Deg.
................Intake..............Exhaust
Centerline......111.00.ATDC.........117.00.BTDC
Open............12.34..BTDC.........60.74..BBDC
Closed..........52.05..ABDC.........4.32...ATDC
Duration........244.7.Crank Deg.....245.1..Crank Deg.
Area............25.45.Inch Deg......25.51..Inch Deg.
Lash............0.0160..............Same
Rocker Ratio....1.73................Same
Peak Cam Lift...0.30308.Inch........0.30357.Inch
Peak Valve Lift.0.50832.Inch........0.50918.Inch
