Old 03-04-2011, 10:49 AM
Keithc8 Keithc8 is offline
Default Fast EZ EFI
Well I think that you would need a smaller camshaft for the Mass Flow possibly even though they say that is not the case. I will check on the lower vacuum to see what the guys at Fast think on this deal. I have used the Mass Flow set up myself but feel that it is limited on the higher HP stuff. I know some people go into the computer on it and mess with it by doing a chip or using a programmer.
On the block we use our RMC CNC block machine. We have a program with locations in it that we set up on to do this. Have to drill from each end and meet in the middle so it has to be pretty accurate. We also have to drill the connectioning galleys from the valley down as well and then tap all holes for pipe plugs. We charge about 400.00 to do it to a block for someone.
Thanks, Keith
Keith C
