Thread: Oil Temp
Old 03-04-2011, 06:48 PM
DAVID GAGNARD's Avatar
Originally Posted by jhv48 View Post
Is the sensor installed well below the oil level in the pan and far enough into the pan to be fully immersed in oil?
That and be sure to check the routing of the capillary line, you want gentle bends,no sharp turns or kinks, if you accidently kink the line,throw away the gauge, cause if will most definetly be off...........
David
DAVID GAGNARD
