Old 03-05-2011, 04:22 AM
Default All for the richmond but
LMH Larry The richmond have the same mount location as most 4 speeds. From my experience the ONLY thing is the shifter setup. I have a short mustang shifter that bends forward about 2-3 inches. If you go with the orginal shifter this will be fine. The issue is it's slow from gear to gear changes. This is the only advantage between internal and external linkage trannies. I do have a vertigate for my 5 speed but it doesn't work on the track to well when down shifting. I have never missed a gear on the up shift. I think the 2.87 first gear will be more than enough to get your car moving. Not sure if they have a couple of different gear sets. If your motor have a good low torque band, the lower overdrive gear would be ok. IMO I beleive that you get what you pay for with any part. I also like the "KISS" method for engineering, The less shafts the better, wider gears, support in case for main shafts. For a better linkage kit for the shifter make your own heim joint rods and bend to work. This removes the springs and plastic washers to the fork arms. I think someone even sell a shifter kit like this. God luck with the trans, Going this way myself. Rick L. Ps check the measurement between the face of the trans and the end of the input shaft. Some tranny need to have the input cut down if using a lakewood beel and a GM input shaft. .380" is the measurement with a lakewood. Some one here sell a shorter shaft, Richmond may also do the same. If you don't check this measure ment you could destroy the thrust bearing in the motor and wipe it out. I use a roller bearing in the crankshaft end, same one for 15 years and no problem. Bushings work fine too.
