Old 03-05-2011, 07:00 AM
COBRAMAN 484 COBRAMAN 484 is offline
Keith, I just installed a new 482 using your 242/248 cam, lifters and pistons. The motor is running but I wont be able to drive it for another month (to much snow). I have been running a TWM 50mm setup with a Haltech F9A running of off the TPS for about twelve years. I've been thinking about a new system for the last few years. Just haven't been able to decide on which one. The Fast EZ EFI sounds interesting, my question is where do you put the plenum box, does the manifold have to be removed and machined or drilled and tapped and what would be the cost for a plenum. Also how does the system run from 0-100' my summer house is about 8' above sea level and has been known to be a few feet under sea level at certain times. Thank You.
Peter
