Old 03-06-2011, 01:11 PM
ACademic ACademic is offline
One cure is to take a length of larger diameter rubber hose (or the clear nylon hose you can find in the plumbing dept at Home Depot). Split it length wise, work it over the section of ANY braided line that rubs up against other steel or hard edges, and then zip tie the outer "sheath" over the braided line in several places (about every 1"). The sheath takes the brunt of the vibration and rubbing that caused your failure.
