Old 03-06-2011, 08:35 PM
LMH's Avatar
LMH LMH is offline
Thanks Brent. I didn't know Keisler's trans had it's own bellhousing. Good info.
Here's what I've found:
Measured from the bellhousing mounting surface to the centerline of the shifter,
the TKO is 12.65" at the mid-shift location.
The Richmond Street 5 spd is 20".
Knowing that the gear case on a BW T10 is 10" and the shifter centerline is approximately 2" - 3" beyond that, it looks like the TKO is closest to original using the mid-shift location. Now I need to find an offset shifter for the TKO mid-shift location to move it towards the driver's side and I should be set for what trans I can use.
Geez! I didn't do this much homework when I was in college!
Alba gu brąth
