  #27 (permalink)
Old 03-09-2011, 11:28 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
well, you can't be using terms light about and this is not exact---
The 4 inch Windsor cranks are out of stock so it'll be a bit before I can weigh one but I'll get some actual weights for you---there probably isn't 5 lbs differance and I wouldn't bet on which one is totally lighter--and don't forget that the windsor will have the added weight of the external balance weight on the front dampner and flywheel .
