Old 03-09-2011, 03:02 PM
olddog olddog is offline
Originally Posted by DAVID GAGNARD View Post
look at the clutches, you should see a "pattern" on the clutches itself almost identical to a clutch disc, if the clutches show no pattern and are smooth, they are worn and I would replace them, otherwise,put it back in the car and add the LSD additive (avaliable at any Ford dealership or parts place) with the rear end oil.....
David
The clutch disks have the cross hatch showing. Is there any way to find out the spec on how thick they should be or the total hight of the stack? The clutch pack is setting on shims. I assume there is a reason a shim was added. Not sure if it is for total hight or to adjust spring pressure.
They look good to me, but I'd like to be sure. I don't want to waste money on parts I don't need, but I don't want to have to take it back apart either.
