Old 03-09-2011, 03:04 PM
olddog olddog is offline
Originally Posted by Rick Parker View Post
Check the "Hat" for hairline cracks in the area machined for the bolts that attach the ring gear. If they are present they will allow the spring pressure to be inconsistant and the hat will eventually fracture, causing huge damage. If you have it apart, time is well spent with a die grinder smoothing out all the sharp edges and corners.
I am assuming you are talking about the carrier only. Not the housings.
