Old 03-09-2011, 04:20 PM
zrayr's Avatar
zrayr zrayr is offline
Cobra Make, Engine: Fords
Originally Posted by DAVID GAGNARD View Post
There is also an additive you should put in the rear end oil with a Limited Slip 3rd member, it is made specifically for this and will reduce the "chatter" and make you LSD work better............."
your Ford dealer sells exactly what you (likely) are needing. It's sold under the Motorcraft brand label.
Z.
'65 K code Mustang
'66 Galaxie 500
