Old 03-10-2011, 09:00 AM
blykins blykins is offline
Originally Posted by Jerry Clayton View Post
Since you are going to be stroking this thingie----and side clearance will be an area that needs some attention----you can relieve(notch) the sides of the rods so that more oil will sling up on the camshaft---A lot of these cam/lifter failures can be traced to inadquate rod side clearance
Jerry, I've been lucky so far...I've only had one Scat crank/rod combo that I had mill the rods down because of insufficient clearance. It was on one of the most common combos too...a 347 SBF.
Very good tip though...I need to sit down and have a Coke/Pepsi with you sometime.
I can't wait to get started on this thing.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
