Thread: Summit Carb
Old 03-11-2011, 05:51 AM
lnfletcher's Avatar
lnfletcher lnfletcher is offline
Cobra Make, Engine: B&B 427 Stroked Windsor TKO 600 w/3.50 posi 9"
Bought one of these after reading this and another post. Result? - Extremely pleased with its performance even though a number of people said it wasn't a performance carb.
Bought the 600 and added the dual feed AN fuel line.
http://www.summitracing.com/parts/SUM-M08600VS/
http://www.summitracing.com/parts/SUM-220104/
I was having a stumble with my Edelbrock AVS 650 and after months of working with it, finally gave in and purchased this carburetor.
Bolted it on right out of the box without breaking it down like I usually do to "see" whats inside.
I had a -6AN fuel line already which is why I bought the optional AN fuel line.
This hooked right up.
Linkage was the same as the Edelbrock with a little adjustment.
Fired right up with the idle a little low. Adjusted the idle and notice a small fuel leak on the fuel line where the gauge would go. Put a little Teflon tape on it and re-tightened.
Idle was very good and need little if no adjustments other than base idle speed.
Choke even worked correctly.
After warm up, I took it out for a test drive and Whoa! Absolutely no hesitation on full like before. Smooth all through the RPM up to 6000 where the limit cuts it.
Best this car has ever run.
After driving it for about 45 minutes and filling back up with $3.85 93 octane at my favorite no ethanol station, I headed home. When arriving home I shut it down and restarted a few times. All it took was a very slight bump.
No leaks and all is good.
I know I haven't got a lot of time on it yet (this will change this weekend) but I recommend this carb for those that just want a good running carburetor right out of the box.
P.S. and it looks pretty good too!
