Old 03-12-2011, 11:48 AM
cdog's Avatar
cdog cdog is offline
Cobra Make, Engine: Titanium SPF, 521 CID Gessford.
To the OP:
You are doing it right.
Left side of shoe on brake, angle foot so you can blip the throttle with right side of shoe. That's what I do.
Question to those that DON'T use heel-toe downshifts: How do you handle accelerating out of a corner since you can downshift while braking? Seems like if you just downshifted and lifted off the clutch, your revs would be all mismatched.
Originally Posted by ramey View Post
the pedal is too low, has too much travel, and the master cylinder is garbage and the bias is a disaster.
I yanked all that that crap out, properly mounted a tilton dual master cylinder with bias bar and pedals...unfortunately, i learned that the spf brakes, pedals, steering and front geometry must be completely redesigned unless you are just wanting to live with a show car only level of performance on 60's technology tires.
Dude, mine is fine. Car handles good, pedals are fine, stops well. I have Avon tires and I'm betting the car will pull about 1g laterally.
Join the N.R.A. -- Homeland Security begins in YOUR home.
