Old 03-13-2011, 05:44 PM
Grubby's Avatar
Grubby Grubby is offline
Cobra Make, Engine: ERA 838
I am using the same bellhousing with the spacer for use with a standard length input. Bell was dialed in to total run out of .004". Pressure plate is the same with a new clutch disk.
Rear suspension was changed at the same time to change gear ratio. I used stock ERA parts, but it is possible the pinion angel was changed some.
