Old 03-14-2011, 03:56 AM
blykins blykins is offline
Slave cylinder?
You may want to check the geometry of your clutch fork/slave cylinder setup. It may not be the slave cylinder's fault. Wilwood makes a great slave and I've used them for years.
Also make sure that the clutch was adjusted correctly. If it's a Long style pressure plate, as the clutch wears, the fingers actually get closer to the throw out bearing.
Having said that, no manufacturer is perfect, so you could have got a bad one. But it's worth checking out other things first just to make sure.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
