Old 01-27-2002, 08:21 AM
skibum2 skibum2 is offline
Default koni's
I have a contemporary with jag. suspension also...the instruction (assembly) manual warns against using any other shocks except the ones that the factory can supply...big letters that start out with "WARNING"...now then....I have a question concerning the rear end....if you can help, the output shaft is leaking at the pumpkin side, if you know, do I need to pull the complete assemby out to change this?..any special tools?..the assembly manual states that the R&D dept. of Koni engineered the shocks for this kit...they are not available over the counter...thanks and I hope this helps...larry
