Old 01-27-2002, 11:21 AM
Hotfingrs's Avatar
Hotfingrs Hotfingrs is offline
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
The car is E-M with C-4 corvette suspension front and rear. The engine started as a 400 SBC the with a .030 overbore and 3.875 stroke, you get 421 inches. Heads are AFR 227 with 2.1 intake and 1.6 exhaust. Fully CNC'd. Lunati crank and Calles 6 inch rods. Ultradyne solid roller cam. .667 lift on intake and exhaust and 267@.050 rockers are Jessel shaft mounted and are 1.55 ratio to make up for what you lose in valve adjustment. Compression is 10.8 and runs on 94 octane pump gas. Intake manifold if Edelbrock Victor and carb is a C & S flowing 900 CFM. Also running a TH350 tranny. Rear gears are\were 3.07 With these gears I ran 10.5's @ 127mph. I've since put in a set of 4.10's but haven't gotten to the track to see a time yet. I know low 10's for sure and possibly 9.90 by the time I get everything dialed in. I run the ET Streets when I go to the drags, I believe they are 9 inch tread. No problem hooking up. 1.50 60' times. shifting at 7200 rpm's.
Jack
XSSIVE .....
