Old 03-16-2011, 10:18 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
about the only situation of when a sway bar causes wierd handling is when the corner wts of the car aren't balance and then one way it helps a tiny little bit and turns the other way are near accidents----The issue of proper suspension needs to have corner weights balanced-( unless running a track where different offsets/rates would help times)
