  #84 (permalink)
Old 03-16-2011, 06:20 PM
blykins blykins is offline
Originally Posted by madmaxx View Post
I would think a 500 hp 351 stroked to 427 would outperform a big block (427,460,482) putting out 500hp due to less rotational mass assuming same driver, same car.
Well, if you compare two different displacements, bores, strokes, etc., then it's really not a valid comparison. A 482ci FE has a longer stroke, larger bore, etc., than a 427SBF and it will also make a higher average horsepower/torque that you could feel across the whole curve.
As for even displacements across engine families, if they make the same horsepower and torque, I honestly don't think there would be enough difference between them to say that one car would walk off and leave the other because of rotating assembly weight.
Rod, Google "buttload".
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
