Old 03-17-2011, 11:26 AM
Z-linkCobra's Avatar
Z-linkCobra Z-linkCobra is offline
Cobra Make, Engine: Everett Morrison, All aluminum small block ford.
Have you changed your gear or are you putting the old gear back with a new pin? You have to change the gear. Once the hole in the gear gets a little slop in it it can shear pins.
Make sure you dont have a rough spot in the distributor either. Does it turn freely all the way around.
" If it wont break em loose in 3rd gear, it aint enough power "
