Old 03-17-2011, 08:48 PM
menace1 menace1 is offline
Originally Posted by Blas View Post
A dash mounted manual fan switch became standard item on chassis 1900 and above. The factory utilized what was the standard electric fuel pump cut-off switch location for the new manual fan switch. (note: an electric fuel pump was not supplied with a new chassis) The actual wiring for a electric fuel pump cut-off switch is still provided with the newer chassis from the factory - just no switch exists on the dash anymore. A dealer or a previous owner may have added your manual fan switch if your chassis number is under 1900.
Blas, On the wiring diagram it shows a brn-blu wire coming off the thermo sw. to the relay but on mine there is just a jumper between the two relays with a brn-blu wire. Any ideas on what color wire and location to tap into to complete a circuit to the fans? Thanks...#1721
