Old 03-18-2011, 06:50 PM
treblig treblig is offline
Cobra Make, Engine: Midstates in-work again
I finally got the new harness installed, added two fan relays, and a self test check. Found out that Holly recommends a 40 micron filter in front of the fuel pump and a 100 micron between the tank and the fuel pump. Install a tank vent system, short throw shifter, valve covers and a expansion tank system. The cars runs great, I’ve been driving it all day, what a rush found out that I need sun screen. Went down to the court house and got my license plates so now I'm legal. Car ran at 190 consistently and oil temp stayed at 195 that’s at the heads and not the radiator.
I still have a few more bugs to work out. Starter hangs for 3 seconds after engine has started, it’s to tight between ring gear and bendix, got a rear end leak need to chase it down, I got 84 corvette calipers in front and wildwood dyilite rear. I think I need to change my fronts to be more compatible with the rears. My bias bar is adjusted out the way all, afraid to go anymore due to binding. Thanks FWB and Jerry for the support, found out today I need MORE POWER!!
Treblig
