Old 03-19-2011, 05:46 PM
Rebel1 Rebel1 is offline
Should also mention the whiteline units look fairly "small" in that pic but they are quite substantial mounts.
The bolts you see are all 10mm. The inside of the urethane bush has a steel sleeve which increases the diameter of the metal support surface area inside the urethane bush. Did I explain that correctly?
Gawd...just noticed the pic clearly shows that bush. )
