Old 03-22-2011, 08:36 AM
petegtsv10 petegtsv10 is offline
Cobra Make, Engine: FFR MKIII, Clayton Racing 429
Originally Posted by CobraEd View Post
That is the same hp as in the Caddy CTS-V where it is de-tuned. The same engine in the ZR1 Corvette is something like 620. I guess they don't want the Camaro to run with the Corvette.
At almost 3900 lbs!!! you won't see a Camaro running with a 3100 lb Vette. The Mustangs are starting to trim weight, but the Camaro is still so heavy. You can mod for more hp all you want, but you will always feel that weight when cornering and braking. A base ZO6 can be right at 3100 lbs........imagine adding 4 45# weightlifting plates to EACH fender of your car and then racing it. That's the difference between a Camaro and a Z.
2005 FFR MKIII 427
C6 ZO6 427 500rwhp
2053cc Kawasaki Vulcan
Victory CrossRoads
