Old 03-22-2011, 10:22 AM
Ron61's Avatar
Ron61 Ron61 is offline
Post
Leecbr,
My worry is after a turn, hopefully the bolt is lined up enough to put the wrench in for the next torque.
I wound up buying a water pump that varies the amount of water pumped with the speed and it had no back plain like the stock ones do but was a one piece cast aluminum one. I ran it hard for to years and never had a leak.
But for the stock one and other hard to get to bolts, I went to Sears and bought some of their ratchet boxed end ranches and shaved that end down to where it would go into the spaces and that way I never had to worry about getting the bolt turned enough to get the wrench back on it. I also modified several ranches to get to other bolts on the Coupe as they were impossible to get to with a regular wrench.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
