I posted this over on the FE forum and thought some of you may want to see it too.
This one is for the Boss 528BBF build. The clutch is rated for 800hp and is made to accept the 1-1/8x26 input shaft size of a TKO 600. They are of course available in other options.
Both discs are organic and the pressure plate is a diaphragm piece, so this makes for a very streetable clutch kit without chatter or bad engagement characteristics.
Due to the anodized adapter ring, the RST will fit any pressure plate pattern. I have this one bolted to the 11" pattern with 5/16" ARP pressure plate bolts.
I forgot to snap a picture of the floater that goes between the two organic discs.
Brent Lykins
B2 Motorsports, LLC
brent@b2motorsportsllc.com
502.759.1431
