Old 03-23-2011, 07:18 PM
YerDugliness's Avatar
YerDugliness YerDugliness is offline
Cobra Make, Engine: Cobra Auto Works body, Ron Godell Racecars chassis, 1989 Mustang GT 5.0 HO (converted to carb), W/C T-5, 3.73's in a Ford 9" Traction-Loc.
Originally Posted by DrGuy View Post
Mike, Bret, Brent, thanks for the info. Brent, If I dont change my rear gears are you saying I should be looking at the TKO 600 with the .82OD? Should I reconsider using a toploader due to my tall rear? The reason I was going with a 5 speed was so I would'nt have to listen to the engine rpms at highway cruise speeds 70-75. I was planning on using the Edelbrock dual plane intake with an operating range of 1500rpm-6500rpm can't remember the Summit code # does this help with a HP estimate
I have a 1989 T-5 with the 3.35 first gear and a 3.70 in the differential. First gear is almost useless, unless you plan on using your car to pull floats in a parade. I have what I think is a "box-stock" 1989 5.0 HO engine from a Mustang GT and I can idle away from a dead stop in 2nd, 3rd, and 4th. I seldom use first, most of the time I only use 2nd, 3rd, and 4th in town. My .675 OD (5th gear) is useless for anything other than highway cruising, but b/c my engine isn't tuned for high RPM use (yet) I can comfortably cruise at 70 MPH at less than 2,000 RPM's and get close to 25 MPG (YEAH....gotta love that!!!). With your cam, you'd not want to do that, it would "lug" the engine and kill your gas mileage (not to mention that the rich fuel mixture at those low RPMs might well wash the oil off your cyllinder walls, and you certainly don't want to invite early ring wear).
Bottom line, I'm glad you're listening to Brent! You won't be sorry.
Cheers from Dugly
YD,E./PNB
No names were changed to protect the innocent!
