Old 03-24-2011, 08:24 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
Dugly
You need to set the bars with the car at ride ht for your weight in the seat(sandbags)
The easist way is without the springs shocks hooked up (initaly)with one of the uppers disconnected, set the lowers to align the rear with the direction of travel(forward and centered) then adjust the connectted upper to set the pinion angle, and tighten those 3 bars end bolts plus jam nuts,and then adjust the other upper bar to fit the attach bolts and tighten those---leave the jam nuts loose--reinstall coiloversand set heights--then turn the link so as it is in a free turning area(by hand)Roll bar back and forth to determine this--then give it about 1/2 turn to preload the rear forwrd(pinion down) as the housing will want to rotateback under acceleration---go for a test driveand enjoy
