Old 03-24-2011, 02:51 PM
Z-linkCobra's Avatar
Z-linkCobra Z-linkCobra is offline
Cobra Make, Engine: Everett Morrison, All aluminum small block ford.
Do you have the plexiglass inspection hole plugs? If you dont go find you some so you can see what its doing. Sounds like to me you tried everything I would have suggested but I want to lean towards your fuel pressure rising enough to over power the needle and seats. Do you have a way to put a temp. fuel pressure gauge on it located somewhere that you can see it while driving to see if thats what its doing?
Do you have a return line on it by chance? If you do could that be plugged? Does your regulator have a vacuum port for increasing fuel pressure as needed. How are you setting your fuel pressure. With just the pump running engine off or engine running? If it has a vacuum port that might be jacking with you.
I dont mean to insult your intelligence an any way by asking these questions. Just throwing out some ideas.
Gene
" If it wont break em loose in 3rd gear, it aint enough power "
