Old 03-24-2011, 09:22 PM
SMOKNAC's Avatar
SMOKNAC SMOKNAC is offline
Cobra Make, Engine: SPF / FE428
Good question? I’ve been dealing with SPF #2990 for some time now. You don’t want one with the new rear-end. (ZF rear-end) The problem I have now (the pinion angle is wrong) after installation of motor and trans is, I have 8 degrees on my drive shaft. You should have between 3 & 4 degrees. At around 45 and up, mph I have a vibration. High Tech did not do the homework prior to installing the new ZF rear-end!! What Dennise Olthoff is telling me is remove gas tank, fab up some brackets’ weld them in, and reinstall gas tank.
Cut off #2960
Try and find a nice pre-owned one...... A lot of good deals out there!!
